Ford Script and Date Code on a Generator? http://i118.photobucket.com/albums/o...psf6e8717e.jpg
http://i118.photobucket.com/albums/o...ps8729766f.jpg Does anyone know what year the "B" represents on this date code? This generator is post Model A production as indicated by the beveled rear edge on the body. The field poles also have Roberstson screws. I also cleaned up a typical Model A generator body that has Ford script and "R 8" for a date code. Does anyone know what year the "R" is and why would it be on a generator case built during Model A years? This body also has Robertson screws holding the field poles in place. I don't recall seeing Ford script on the other Model A generators I've worked on, except for a few powerhouse generators that had Ford script on the mounting bracket. |
Re: Ford Script and Date Code on a Generator? It is not referenced in the 35-36 restoration book, but I have seen similar marks on V8 starters-gen ---there was a post that talked of original date codes but I don't remember when or where, I have a known original 31 gen, the date code is on the band, letter for year, number for month is what I remember form the article, the armature had a date with normal numbers, I am surprised that judging is not explicit about date codes,
Re: Ford Script and Date Code on a Generator? Anyone know the date codes?
Has anyone seen a FORD script on the common long Model A generator? |
Re: Ford Script and Date Code on a Generator? As far as the band's go i think(H=’27, I=’28), J='29, K='30 and that L= '31.
That came off of Pluck's site. |
Re: Ford Script and Date Code on a Generator? When I see such codes on parts my first thought is that the letter is for month, the number is for year, I will try to look at Hershey, I don't think that the letter for year would work, it would be too many years to get back to "B", there wouldn't be much reason to make new housings for such an old style generator, but feb 37 is in line with that style, and possibly feb 47
Re: Ford Script and Date Code on a Generator? Kurt, sometimes date code letters repeat themselves after "Z". then B might mean 1946 and 7=July?
Re: Ford Script and Date Code on a Generator? 1 Attachment(s)
Here's another...slightly different. No marking on band.
Re: Ford Script and Date Code on a Generator? Quote:
Re: Ford Script and Date Code on a Generator? 2 Attachment(s)
Here are2more from my 36 pile, 33-39 V8 style ---interesting, the letter and number are reversed in order between them
Re: Ford Script and Date Code on a Generator? Also interesting is the dash between the number and letter. One has it, but not the other. I don't recall seeing any dashes on Model A date codes.
Re: Ford Script and Date Code on a Generator? I have found the same thing Kurt, thought my dislexia was acting up. Rod
I just bought this generator at the local flea on Sunday and was amazed to see the tiny (1/4") Ford script and the code S-9. It looks like new, no rust, and clean inside. Not sure what I have here, but I'm only out $10 !:)
Re: Ford Script and Date Code on a Generator? That would be a 1938 generator. Rod
