Peep mirrors I bought a clip on peep mirror from the standard vendors. It is the straight shank, and I mounted it just above the hinge. Worthless. It is angled out so far that you can't adjust it in enough to see anything. Are they all like this? Is the bent arm one better?
I didn't feel like going through the expense or effort for a hinge pin one, but I'm not sure what else to do. It's tough driving without mirrors.... |
Re: Peep mirrors I don't know if this will help, but a good way to adjust side mirrors is to have them pointing towards your blind spots. The rear view mirror in the center of inside the car will let you see behind you and as a car passes it will disappear in that mirror and appear in the side view mirror at about the same time. As it disappears from the side mirror it will appear in you peripheral vision. This arrangement has saved me from pulling into the lane of a passing car many times. I can keep my eyes ahead and don't have to turn around to see what is in my blind spot.
Re: Peep mirrors I can't even see cars in the opposite lane because it's angle so far out. I'll take a picture of the mount, it looks like it's bent wrong. It gets worse when you insert of rubber protector.
Re: Peep mirrors Accidents are a huge PIA. I have a hinge pin mirror on each side. They are not bad, and well worth the few bucks paid. As far as I know safety items are not a deduct for points when fine point judging.
Re: Peep mirrors I have the ones with the bent arm that the mirror pivots on a ball and socket joint. Its still nearly absolutely useless. I'll get it set right and by the time I get to where I'm going its shifted position. Even when its in the right spot, I have to close one eye to really make out if there's something there or not.
On the passenger side I pointed it down at the rear wheel so I can see how close I am to the curb when I'm backing in. That's about the only time I bother using my outside mirror |
Re: Peep mirrors You can get stick-on convex mirrors that help a lot. I have some that are the exact diameter of the flat mirrors.
Re: Peep mirrors I have the hinge pin mirror arms on both sides of my CCPU. I have 6" convex mirrors again on both sides. Best combination ever. Arms came from Snyder's, mirrors from Amazon.
Re: Peep mirrors I also have the one with the ball socket joint, but my mirror vibrates so much I can't see anything out of it
Re: Peep mirrors Many many years ago, before the internet, there were articles in the magazines about how the vibration pattern in your rear view mirror could be used to analyze your engine. A certain pattern, say a slanted oval was a loose rod bearing and straight up and down was a loose main bearing. I now think it was pure BS and meant to be funny. But back then I thought it was a serious thing.
Re: Peep mirrors Let's see a picture of the mirror mounted on the car. That will be a big help.
Re: Peep mirrors 3 Attachment(s)
Pictures of the mirror and on the car. The clamp bracket doesn't seem bent right and it seems too far recessed into the arm. On the door you can see the main part of the stem is not at a 90 degree angle or less, and hence I'm looking practically sideways.
Re: Peep mirrors 2Speed, will the mirror pivot 1/2 turn, to allow more of it to be 'away' from the door? Perhaps it's just the camera angle, but it looks like the adjustment ball is not halfway along the mirror, allowing a bit more mirror to be further away from the door...
Re: Peep mirrors That’s the way I see it too, the mirror needs to be rotated 180 degrees to give the range you are looking for (pun intended). I would understand if you preferred it the way it is but I don’t know any alternative.
Re: Peep mirrors Did that, didn't help, I was trying it on the passenger side to see if it worked there, that's why it's adjusted different.
Re: Peep mirrors Put it on the front of the door, that will work.
Re: Peep mirrors If you rotate the mirror 180 degrees the mirror will then be able to look more toward the center of the car. Twist it 180 degrees.
Re: Peep mirrors Rotated every which way, every degree, and it is mounted on the front edge of the door, I cannot see the edge of the car. I'm going to fab my own mounts.
Re: Peep mirrors 2speed, if you can see the edge of your car, you have the mirror tipped in too far. The side mirror is supposed to look "out" further to the side.
Joe B |
Re: Peep mirrors I ordered jeep mirrors off Amazon.
"LIBERRWAY Door Off Mirror Compatible with Jeep Wrangler TJ JK 4x4 Off-road Morror Rectangular Mirrors Quick Release Side View Mirror, right position, 2 Pack" item B07J1VX6Z6 Sorry I don't have the post count yet to link directly or post pictures. I also tried the peep mirrors and found them worthless. For these jeep mirrors I did have to drill holes and mount them to the body. But I don't think they look too out of place, and I've been very happy with them. Can't beat the price at $27 for a pair. They do vibrate some, but they hold their position, you can still clearly see the cars behind you, and they offer a nice wide view beside and behind. They don't impact the way the door opens at all on my slant window. ~Ernie |
Re: Peep mirrors While I know there is a hot debate on how to adjust your side mirrors, but I drive truck, and not being able to see the edge of your vehicle in the mirror does not work for backing up, especially with the narrow back window of a Model A. It also does not work when someone is 2 feet off your rear end. For me, seeing the back corner is a necessity.
