Motor stand adapter for Model A engine Are there any good how to designs to make an adapter to hold the model A engine? This is my first tear down of an A engine and it looks like I need to bolt it up twice. Once at the flywheel housing and at the water passage on the side of the block maybe?
Re: Motor stand adapter for Model A engine Most of the parts dealers have a ready made engine holder that fits a generic engine stand. Cost is usually around $110 but well worth it. Bolts to the water inlet side and secures at the oil pan rail.
Re: Motor stand adapter for Model A engine Quote:
If you use the commercial product you won’t need to grab it at the flywheel end, which takes care of that issue. |
Re: Motor stand adapter for Model A engine 1 Attachment(s)
The threaded holes where the water inlet is are strong enough to hold an engine. Use grade 5 bolts and make sure they bottom out in the holes. Add washers if necessary to make the bolts fit tight.
Use some tack welds to keep the arms that are supplied with the stand from moving. You can grind off the tack welds if you want to use the stand for a modern engine. |
I always kind of liked the engine stand in Victor Page's Model A book - it has the advantage of a "gear" rotation. But it suffers from "two rails" and impeded access. There is no perfect engine stand. https://thumbs.worthpoint.com/zoom/i...7ea1eafb5b.jpg https://thumbs.worthpoint.com/zoom/i...7ea1eafb5b.jpg https://thumbs.worthpoint.com/zoom/i...7ea1eafb5b.jpg https://thumbs.worthpoint.com/zoom/i...7ea1eafb5b.jpg Joe K |
How stable is that? I have the stand with 4 wheels. |
Re: Motor stand adapter for Model A engine I bought one from snyders, although it seemed like a lot to spend.
No regrets, though. It's very solid, and allows you to spin the motor nose down, which makes hanging the flywheel much easier. Also, there are two pins that engage a couple pan mounting holes in the block. The water neck bolts are strong, but I like having 4 mounting points |
Re: Motor stand adapter for Model A engine Just a hint: On mine, I drilled and tapped a couple of holes in order to have a place to store the bolts I use to bolt the adapter to the engine, that way I don't have to turn my shop upside down looking for the bolts when I need to use it again.
Re: Motor stand adapter for Model A engine You can use the “search this Forum” tool in the upper right hand corner. Search for “engine stand adapter” and you will find many discussions that include how to make your own adapter.
David Serrano |
Re: Motor stand adapter for Model A engine Just FYI for you guys on engine stand adapters. The KRW stands have the engine pretty well balanced. The center of rotation on a KRW stand adapter is 7" from the bellhousing surface and about 4 1/4" from the pan rail. If you are going to make one, I'm pretty happy with that balance point.
Re: Motor stand adapter for Model A engine They want 185.00 now and i feel i can make one for less. Just wandering what others have done
David Serrano |
