31 coupe adjustable seat I need some help with a diagram or pictures of a 31 coupe seat adjuster. One of the guys in group can't get the seat mechanism to,work and we're not sure if we have a missing part or if it's not assembled correctly. Pictures or drawings would be awesome! Thanks!
Re: 31 coupe adjustable seat Does it not work due to lack of oil, or is something missing or assembled wrong?
Re: 31 coupe adjustable seat Mine just has a screw and knob, bracket on the seat frame holds knob and screw, nut is on seat riser bracket, slotted slides on seat riser, wood seat frame bolts to track---perhaps there is other version with ratchet too
Re: 31 coupe adjustable seat My 30 coupe is as Kurt describes, I could take a picture with the cushion removed if you want?
Re: 31 coupe adjustable seat Is it the late 31 ratchet type or the earlier screw type?
Re: 31 coupe adjustable seat Pictures would be great. It's this screw type not the ratchet
Re: 31 coupe adjustable seat The later 1931 used a different mechanism which did not have the twist knob as did the earlier vehicles. The later style had a unique handle which you lifted up and pushed back on the seat, The mechanism had notches and you pushed back until it fell into the desrired notch. I am sorry that I don't have a photo readily availableas my coupe is presently stored for the winter.
Re: 31 coupe adjustable seat 2 Attachment(s)
Most of the A parts houses carry repros |
Re: 31 coupe adjustable seat This should be on the bottom of the seat:
http://thumbs.ebaystatic.com/images/...K5-/s-l225.jpg The screw should screw through a hole in the seat riser and pull the seat forward and backward. (photos compliments of Napa Skip) http://www.fordbarn.com/forum/attach...1&d=1375229306 http://www.fordbarn.com/forum/attach...0&d=1375228996 This piece should be mounted to the crossmember in front of the seat riser https://www.brattons.com/catalog/sea...nut-35800.html https://www.brattons.com/media/catal...5830_1_2_3.jpg If that cage is there, but not the special nut that the screw goes through, you can just order the nut. https://www.brattons.com/catalog/sea...sting-nut.html https://www.brattons.com/media/catal...5800_1_2_3.jpg Bratton's has all the hardware at the link below if you don't care about original parts https://www.brattons.com/catalog/sea...are-front.html |
Re: 31 coupe adjustable seat Thanks so much!
