Lead filling on firewall Hi Barners,
I have welded numerous circular patches into my firewall due to PO loving to drill. Now that they are welded in is it OK to finish the areas with a thin layer of lead? Thanks, Bruce/CT |
Re: Lead filling on firewall Sure if you know you won't be doing any more welding on it! I learned how to use lead on my avatar roadster. Pretty easy but you must be safe and be sure to clean the acid left over from tinning. I don't think anyone ever fixed a heater, they just went to a junkyard and got another one and punched a couple more holes in the firewall.
Re: Lead filling on firewall Lead's nostalgic, but with today's modern fillers there's really no need.
Re: Lead filling on firewall Did auto body repair for a living when lead and Nitro-stan putty was the only thing available.
Today, as '19Fordy' says, no need for lead. So long as thickness is kept to a minimum. No acid, no tinning, no neutralizing etc. |
Re: Lead filling on firewall Quote:
Re: Lead filling on firewall That reminds me of something I learned when I was first into cars .
I was watching a Dick Falk leading up the firewall on a '34 roadster. He had the firewall on a jig. When I asked him why he mounted it that way he just said "have you ever seen lead run up hill ?" I agree with the previous posts- no need for lead with the products out there today. |
I don't even have any sticks of it left around . . . fine by me. :rolleyes: D |
Re: Lead filling on firewall He asked if it was OK, not if it was the best alternative. All my early Fords have factory lead on seams on them somewhere. His choice. There is probably a couple of table spoons of lead I applied to my roadster and can truthfully say there is no plastic filler on it anywhere--and I painted it black. Haven't used any lead since but wanted to try to get the metal as perfect as I could as a challenge.
Re: Lead filling on firewall Any suggestions for a filler in place of lead ?
Re: Lead filling on firewall Eastwood sells several kits. Lead is the way Henry did it.
www.eastwood.com/leading+kit The link doesn't work type in Leading kit Dave/Green Bay |
Re: Lead filling on firewall There are still a lot of folks that don't use anything but steel. My first experience with hammer welding was watching an old guy weld up holes in a model A body. He would grind around on the rust holes till he got the thickness back to a weldable range then fabricate a piece of steel to fit the hole by tracing. He made them fit tight and used magnets to hold them. He had an oxy/acetylene aircraft torch with small tips and used it to weld the holes shut working a small spot at a time and letting things cool a bit in between using the dolly to tap the weld joints a bit as he progressed. The fit was tight enough that he rarely used any filler at all. Some warpage can happen in flat panels so the art of shrinking comes into play to relieve that. The hammer and dolly work is usually done to take the shrink out that happens with the welding and help level a weld that has a bit of crown. When you don't use filler, the crowning effect is minimized.
When you do it this way, you can use spot putty to fill the imperfections after filing & grinding. |
Re: Lead filling on firewall That description of hammer welding is accurate. I am not an expert on hammer welding by any means, but I did do a couple of real nice repairs ages ago using that technique. And I learned to shrink with heat and hammer.
Re: Lead filling on firewall NOT sure if any of you ever have seen a periodical table ? gold is at the top or real good--- silver is down the list ----lead is farther down the list and steel is below lead. the theory is if you placed a pound of gold-silver-lead--and steel out in the field. and came back in say 1000 years . the gold - silver - lead would still be there. the steel would be gone. (rusted away ) Now when you put two different metals together the metal on lower place on the periodical table becomes the sacrificial metal the one above. So the steel (your car ) becomes the sacrificial metal to the lead. So this is what I have always said :( after I learned it ) why put something on your car that can make your car disappear or go away. ( one note : MY 33 roadster was restored in 1971 I redid some lead work that had rusted out. I removed all lead and cleaned what was left of the metal I then re leaded the area . I should have welded in new metal ) NOW 40 + years later the area is going away again --I can repair but paint is old fashion lacquer and the area has striping by ( Tommey the greek )Something that supports my claim ( Steel ships attach huge plates of aluminum to the ship and the aluminum becomes the sacrificial metal so as the ship does not disappear.
Re: Lead filling on firewall Whizz--I don't buy your theory. If that were true, the factory leaded seams on our old cars would be the first to go. What is more important chemical wise is the valence of the element which also indicates how reactive it is to gaining or losing electrons. When a substance gives up electrons it is called oxidation (Rust, iron oxide a product of oxidation), if it gains electrons it is called reduction. Lead is very non reactive as you note, however, it has no effect on the steel. If subject to an oxidizer (air, water) it would rust whether the lead was there or not. This is Chem 101.
Re: Lead filling on firewall I guess you didn't read or understand what I wrote. In order for the steel to become a
sacrificial metal it needs several things. oxygen or as you call it air and as you know air has moisture in it. so the primer and paint keep every thing fine for a period of time---not forever. My point is simple why put something on your car body that can make your car go away. why not use something that has no effect on your car body. |
Re: Lead filling on firewall So you are saying at some point in the future, when the steel is exposed to the elements that can oxidize it, it will rust because there is lead somewhere near it? It will rust anyway in that scenario whether bondo or lead is near it. I think you are worrying about something that is irrelevant. (Have you never seen rust under bondo? )
I also suspect that a sacrificial metal is only relevant when an electric current (ie electrons) is involved due to either electrolysis or an actual grounding like in a metal hull on a vessel in the water. I know, in 1000 years let's compare our cars! |
Re: Lead filling on firewall I think it's a good idea.
เดิมพันบอลออนไลน์ |
Re: Lead filling on firewall (Have you never seen rust under bondo?
Of course metal will rust under body filler. Plastic body filler is porous (spelling) and will absorb water if it gets wet which usually happens before any paint is applied usually due to wet sanding. Get a chip in the paint all the way to the filler and water will soak through to the metal and rust will start, it may take longer that way but it will happen. But in saying that I would use a quality plastic filler before lead in most cases. I refuse to use the word Bondo it was the original plastic filler and wasn't that great not like todays fillers. I have been using Plastic fillers since June 1966 as a professional. |
