Manifold heater time - what kind do you have? 2 Attachment(s)
I have a Red Head heater, but am missing an original door.
Here is a picture of the heater and the door. What other brands of original accessory heaters do you have? Can you post any pictures of your heater and it's door? (If anyone has a red head door for sale, please let me know.) |
Re: Manifold heater time - what kind do you have? 3 Attachment(s)
I have an Auto Lite. The pictures show it with a solid extension tube that someone pressed into the back to connect to the door. I've removed the solid tube and will replace it with something flexible when I fit it to the car.
Interested in the Red Head door, Neil. Does it actually have two flaps, with one allowing for directional air flow, or am I looking at your picture wrong? As my car is RHD, I've got to rig up an elbow inside the cab to redirect the hot air in the direction of the passenger seat where it's needed most (for my wife!!). There's a "hot air/wife" gag in there somewhere, but I'll leave that to someone else! :rolleyes: |
Re: Manifold heater time - what kind do you have? Yes it does have a second flap that will direct the heat.
I've seen that type for sale on ebay before. I have a plain door that I was going to try to put the face on. I can look to see if I have a second directional door, if you are interested? For some reason, I did not realize that you had cold weather in Australia. Neil |
Re: Manifold heater time - what kind do you have? We do have snow here in OZ, it is not all outback and kangaroos bounding down George street.
Around zero C or 32 F is where we draw the line to put the roof up on the roadster. I have driven over the Blue Mountains on the way to the Bathurst 1000 in a mustang convertible with top down when it was snowing. Mate in passenger seat was ducked down behind dash, I said , 'what a wuss ya are ' ..... |
Re: Manifold heater time - what kind do you have? [QUOTE=Neil Mylar LakewoodCA;1175906]I can look to see if I have a second directional door, if you are interested?[QUOTE]
Thanks for the thought. It looks like the directional door will only direct the air downwards, not sideways to the opposite side of the cab? Quote:
Re: Manifold heater time - what kind do you have? Quote:
I have a Red Head, Director (looks just like the Redhead), an Auto-lite that bolts on the waffle manifold and an Auto-lite that clamps on a smooth manifold. On the shelf I have an unknown brand of heater/manifold that has a removable cast iron cover and the outlet uses a flex tube and exits thru the floorboard. Been thinking I may put it on the 400A. Just don't want to cut the expensive carpet but better than the firewall.:rolleyes: |
Doing this it that way is more complex with a RHD car. It's a bit crowded on the RHS of the engine bay! |
Re: Manifold heater time - what kind do you have? No heater yet. Likely will use a hot water type heater as all of my waffle heaters have cracks and are just wall hangers. Have several firewall heater doors that may end up as wall hangers also. Rod
Re: Manifold heater time - what kind do you have? Manifold heaters "trumpet" every engine noise into the passenger compartment. Hang one on your exhaust and the clatter will make you think the whole shebang is coming apart. On the good side, when you get used to the mechanical symphony it will be spring and time to take it off. Then the engine will be soooo quiet you will forget that it is running.
Avoid this dissonance. Invite a pretty copilot to ride along. Mine keeps me from getting lost AND, a couple "slide over baby" right turns snuggles her close. MMMmmmm, warm. |
Re: Manifold heater time - what kind do you have? I have a manifold heater that was made for the stock manifold, as it has baffles inside to slow the air so it heats better. At least in theory. I find that manifold heaters work great when it is cool, and one hardly needs it, and not so much when it is cold and one really needs one. My father told of driving before WW2 with a manifold heater, and when he worked the engine hard while climbing a hill, sparks came through and damaged the silk stockings my mother was wearing.
Re: Manifold heater time - what kind do you have? 1 Attachment(s)
http://www.aircraftspruce.com/catalog/appages/scat.php |
Re: Manifold heater time - what kind do you have? i have the same heater on my 31 PU. i had to make the cover, but did a good job. the register was not the correct one but works great. i cut opening in floorboard and use a solid pipe to carry heat. again, works great. can't remember how i fit it, just went slow and it fits fine. tom w is right, noises come out of the opening that i never heard before.
Re: Manifold heater time - what kind do you have? I have the top part of an Autolite and part an exhaust manifold for a heater, but I don't think the two go together. Hmm. Need to sort that out.
I do have the Red Head door. |
Can't tell from the photos, but I'm sure one of them is a "Redheaded heater"
I have a Autolite wit the firewall door and directional louver. If pointed up, it helps with windshield fogging.
Picture of door
