Rust Removal, Fast easy and Cheap 2 Attachment(s)
Thanks to Mark for this handy tip on rust removal. Mark bought a cheap crockpot at a garage sale, then used pure white vinegar at 170* for 3 hours to remove the rust from these parts.
"Here is about three hours of de rusting at 170 degrees. You need to rinse with dawn dish soap under hot water and using a parts cleaner brush and a small wire bush to clean the corners (really no effort) flash rust will develop almost before your eyes. Here are the parts sprayed with WD 40 to prevent the flash rust." |
Re: Rust Removal, Fast easy and Cheap Will the iron acetate be stable or will it convert to iron oxide under the wd40? I?s iron phosphate (phosphoric acid v acetic acid) more stable in an oxygen environment
Re: Rust Removal, Fast easy and Cheap How about after rinsing, just put in a bucket of deisel oil till needed later?
Pluck |
Re: Rust Removal, Fast easy and Cheap I like it. Now I wonder which crockpot my wife won't miss.
Re: Rust Removal, Fast easy and Cheap The secret ingrediant for next years Hershey chili ---model A iron
Have the brake shafts been taken apart, what happens inside, does it remove the grease? |
Re: Rust Removal, Fast easy and Cheap If you live in an area which salts the roads or near the ocean, do not use WD-40 for anything. WD-40 and salt air are the best rust making combination ever. I won't allow it in my shop at all anymore.
That having been said, good idea on the rest. :) |
Re: Rust Removal, Fast easy and Cheap I just did almost the same thing that Tom did a few days ago, only I used Evaporust instead of vinegar. I am wondering if vinegar would work about the same and much cheaper. However, I was afraid something like an acid, even a mild one like vinegar, would cause problems with the brass cladding or get trapped under the cladding and cause trouble. I am trying to separate the steel backing from the brass cladding to get it replated - it is really crimped on tight and still haven't figured out how to remove the cladding without damaging it. I needed to derust the center bumper emblem that was pretty rusted. The heated Evaporust worked great, much faster and better than when I used it unheated. I used the low setting on the Crockpot and the Evaporust didn't boil, but was quite hot. I let it cook for a day and the small amount of the Evaporust was looking pretty discolored (would have probably still worked OK), but I dumped it (maybe 2 or 3 oz.) and put some fresh Evaporust in the jar for a second day. Unfortunatley I didn't think to take a picture of the setup in the Crockpot. I put about 3/4" of water in the Crockpot, put about 3/4" of Evaporust in a small glass jar, put the emblem in the jar and set the jar in the Crockpot. I used much less Evaporust ($$) this way. I was concerned about the brass is why I did the "douple cooker" method. Normally that wouldn't be necessary. I am posting pictures of before and after the derusting operation. I got a little flash rusting (top part) as I didn't dry the steel immediately after removing it from the Evaporust. Next time I will.
Rusty Nelson http://i201.photobucket.com/albums/a...ps80bab2a4.jpg http://i201.photobucket.com/albums/a...psf36f3c45.jpg |
Re: Rust Removal, Fast easy and Cheap Quote:
A good rinse in baking soda will nuetralize the acid in the vinegar. MIKE :) (mikeburch) |
Re: Rust Removal, Fast easy and Cheap Any rust removal by a wet method just needs to be blown dry immediately.
Only a very fine or no flash rust will appear. Of course it will rust if let to dry naturally. |
Re: Rust Removal, Fast easy and Cheap 1 Attachment(s)
Bill W. |
Re: Rust Removal, Fast easy and Cheap Does anyone else use Gibbs? I have found this product to be excellent in rust prevention. Use on bare metal after bead blasting, sanding, hot tank etc. and no rust appears for months on the bare metal
Re: Rust Removal, Fast easy and Cheap I use Gibbs as a penetrating oil, but am almost out of it and haven't found it at the usual swap meets I attended this past summer.
Re: Rust Removal, Fast easy and Cheap the bicarb will neutralize any acid remaining but the iron acetate may not be stable
Re: Rust Removal, Fast easy and Cheap One more thing about this process that I like is that the spent cleaning vinegar is not dangerous and disposal of doesn't make me feel like I'm endangering anyone.
Re: Rust Removal, Fast easy and Cheap Tom, what is "pure" white vinegar? Just the normal solution you find everywhere?
Re: Rust Removal, Fast easy and Cheap Aojo and Tom. The alternative to Gibbs oil is 4 Way Penetrating oil. Brookville Roadster uses this on bare metal. I have had it on bare metal for almost a year. If you get a little rust from sweat or something Scotch Brite and a little
4 way shines it up. The nice thing about it is it contains no silicone so it is easy to clean for painting. http://catalog.antiseize.com/viewite...---penetrating John |
Re: Rust Removal, Fast easy and Cheap 4 Attachment(s)
As it turns out I was in the middle of a little rust removal as well.
I had heard that for larger parts you can just put them in a plastic bucket with Vinegar and Salt. One gallon of vinegar to a cup of salt. I have no idea why the salt, but it worked great.. Without heat it does take longer, but after 9 days my old running board luggage rack came out virtually rust free. Even the clamp bolts that would not move were clean. I just brushed them with a hand wire brush and this is the result. They do start to rust even in dry Colorado air in about 10 minutes if you don't put something them. I paid no attention to what kind of vinegar, just grabbed the cheapest.:p |
