Need engine in TODAY!! Got a open frame so easy peezy! My question is I just have a engine hoist and the regular chain to plug holes (no leveling device) Putting in engine and trans together. The trans end tilts way down. I'm a one man operation. Chain is in # 2 and 3 plug hole. Any way to level this motor out?
Re: Need engine in TODAY!! Did you try 3 & 4 holes?
Bob |
Re: Need engine in TODAY!! Or just #4
Re: Need engine in TODAY!! I'll give her a try on those...just dont want to crack the head.
Re: Need engine in TODAY!! 4 hole never had a problem
Remember it's all nuts and bolts:) |
Re: Need engine in TODAY!! No problem, as you can lift the rear as it's lowered, or block it with something, then as the flywheel cover rests on the rear motor mounts the front will settle into place.
If the rear is already in place, then it will need to be level enough to start the splines into the U-joint first. |
Re: Need engine in TODAY!! Getting ready to replace engine. What is best way, with or without transmission?? Seems like without would be easier, don't have to remove tower and linkages etc?
Re: Need engine in TODAY!! Well I just got the read mounted in.....now does the front mounting bracket bolts go through the two holes on front crossmember and then secured in block?
Re: Need engine in TODAY!! Quote:
If it's the late 1928 and later with the yoke mount, then I'd set it in place with the springs and install the nut on the bottom and the 2 bolts into the front of the engine last. |
Re: Need engine in TODAY!! Tom it's a early '28 judging by the cross member so solid mount. Let the vibration begin. I could cut it off and use the yoke but too lazy....hahahhaha
Re: Need engine in TODAY!! Go to Harbor Freight and buy two ratchet straps for around $10-15 bucks. Place one around the bell housing and hook it to the hoist. Put a bolt in the generator mounting hole. Connect the strap from the bolt to the hoist. You can get the angle pretty close for installation.
Re: Need engine in TODAY!! YAAAAAAY, Beauford, you did good!!!
Bill Nosweat |
Re: Need engine in TODAY!! Thank you Mr Bill!!!
